Spools
Old Feb 3, 2008 | 03:47 PM
DFour's Avatar
Default Spools
can anyone suggest the best spot to drill for spools? standard steel tapping bit? 6,8,10mm? any pictures would be appreciated.
Old Feb 3, 2008 | 04:13 PM
StreetPower's Avatar
Default RE: Spools
use the bit for which the spools are designed. i bought myself 8mm rumble's(pro-bolt), i'm waiting for them. i would think that ye closer to the rear axle,ye better. maybe even near the axle.. higher?
Old Feb 3, 2008 | 10:21 PM
charlos's Avatar
Default RE: Spools
be careful where you install the spools. in general, people will weld a piece of metal to tap into, on the bottom of the S/A for clearance issues w/ the exhaust.
Old Feb 3, 2008 | 10:31 PM
PlayfulGod's Avatar
Default RE: Spools
ORIGINAL: charlos
this is the best way like he said. I drilled n tapped into the swingarm, along the center line just b4c the weld. Make sure you have it far enough back so you have clearance for the akle to clear when you remove the rear wheel.
I took my spool bolt to a industrail supply and told em I needed a dril bit n tap for it. tap is a 8mm tho.
Old Feb 4, 2008 | 05:01 AM
Default RE: Spools
oh, that's a good point to consider. thanks for the tip
CorruptFile
May 21, 2013 10:35 AM
forshow05
Aug 18, 2010 01:04 PM
02F4iPadua
Nov 19, 2008 11:14 AM
sbv32
Jul 5, 2006 02:51 PM
woodyracing
May 8, 2006 11:49 AM
