Speedo/tach/temp wont work
my neutral light is the only thing that works on the cluster. Back lights all work but there are no numbers ever with the speedo and the tack never moves from 0. its an 02 f4i. I checked the fuses under the seat and have the front off and everything is hooked up and i cant see any shorts. any suggestions. it worked fine on friday and then on monday i had nothing and cant figure it out. headlights, blinkers, etc all work. thanks in advance, mitch
take off the cluster, and there are wires going to the inside of the cluster. it is covered by a plastic panel with 2 small screws. take that off, and you will see 2 plugs. most likely, one of the plugs came loose. same thing happened to my bike once.
