Slowing down aftermarket turn signals?
Old 01-04-2007 | 05:02 PM
woot's Avatar
Default RE: Slowing down aftermarket turn signals?
When you said relay I was thinking of a relay that you'd use for connecting an airhorn or heated vest - where you use aswitched power source to open the relay, but would draw power straight from the battery... i.e. connect the horn wire to the relay so when you hit the horn button the relay opens and power is drawn straight from the battery (not through the horn relay/fuse) to run the larger horn.
So where/what is the relay you're using instead? I know more than one person who'd like one.
Woot.
Old 01-04-2007 | 05:37 PM
CBRtokyo's Avatar
http://customdynamics.com/trick_flas...e_Rate_FlasherI found this site with some answers, thanks for all the help and ideas.
Old 01-05-2007 | 01:00 PM
drprcbr's Avatar
okay, so two questions-
#1: if you choose to use the "relay method", do you need one for each signal or one for the two rear signals and one for the two front signals (i am replacing both f&r)
#2: if you choose to use the "resistor method", do you have to wire the resistors into the negative wire as well as the positive in the rear and the flasher wire in the front
thanks guys!
Old 01-05-2007 | 01:51 PM
knightslugger's Avatar
ORIGINAL: drprcbr
No, you only need one for the whole thing. your bike only has one relay for all the signals. that's the only thing you're replacing. It's a one for one replacement. one relay will control all four lights.
thanks guys!
You need one resistor connected to the positive and negitive wire of each singal.
Old 01-05-2007 | 03:26 PM
Tahoe SC's Avatar
is that right? you wouldn't need it for the ground. i need to go check my wiring. i don't remember wiring it to the negative.
Old 01-05-2007 | 06:34 PM
the resistor wouldn't work properly if the load only got passed through it. remember, the resistor has to service two circuits: the light bulb and the relay. just going through the positive cable only services the bulb.
it's all electrical. circuits in series and circuits in parallel.
Old 01-05-2007 | 08:37 PM
kash's Avatar
You only need a resistor on the positive (red) wire of each turn signal.
Old 01-05-2007 | 08:38 PM
god i wish i had my bike right now... i'd make a friggin movie right here and now.
Old 01-05-2007 | 08:47 PM
kash's Avatar
All I'm saying is thats what I got on my LED's & it works. If you would like to put a resistor on the negative wire thats fine too. As long as it works.
Old 01-06-2007 | 12:52 AM
jimd2p's Avatar
When I got my integrator, it had resistors on the positive wires only. Pretty flimsy, so I got rid of them and got one of these flashers:
http://cgi.ebay.com/ebaymotors/ws/eB...m=110050039532
Works great, easy to install and cheap.
magnumRT
07-12-2012 09:52 PM
Failient
05-25-2010 12:26 AM
Lowridese
05-01-2010 01:12 AM
FieroGT3800SCII
10-26-2008 01:53 PM
01600F4i
09-11-2005 06:46 PM
Quick Reply: Slowing down aftermarket turn signals?
