Scorpio Alarm
Old 11-01-2006, 05:58 PM
amnesia's Avatar
Default Scorpio Alarm
I just bought a Scorpio Alarm for my '05 F4i and I was wondering if anyone has installed one on an '05.
I'm trying to remove the rear cowl (around the seat) and I can't get the 4 hex bolts that attach the grab bar off . **** they're on tight! Is there any trick? (I don't want to bust the damn things!)
Any help appreciated
Old 11-02-2006, 12:48 AM
RojerLockless's Avatar
Default RE: Scorpio Alarm
twist the **** out of them, you gota think they are bolted on to your subfram for holding on to for dear life.. they cant be on weak
Old 11-02-2006, 01:14 AM
CBRCRF's Avatar
Sometimes you have to tighten them a little to brake them free. Not to much, just a little to be able to lossen them. But like I said "sometimes".
Old 11-02-2006, 01:50 PM
i have the exact same bike as you--same alarm too. you don't need to remove the tail or the grab bar to mount this system, just take it and remove your tail fairing bolts to the subframe. and pry the tail away from the frame and slide the control unit along the subfram till its almost all the way back to the rear of it, then mount it vertically along the side of your subframe. thats where i put mine, worked like a charm--took me about 1/2 hour to install the whole thing. good luck
Old 11-02-2006, 04:49 PM
amnesia's Avatar
Hopkinslax12
That's exactly what I want to do. This is why I hate taking apart my bikes. I'm usually taking off the wrong piece (which I then brake)!
The alarm is great and I highly recommend it.
Thanks for all the help
Amnesia
600cbr18
02-01-2011 11:20 AM
bieniu
03-27-2008 10:01 PM
mark986
03-31-2006 07:30 PM
Quick Reply: Scorpio Alarm
