A couple questions for the Guru's
So back story is I lowsided my bike about two weeks back snapping off the brake cable, rear brake lever, mirror, bar end, crackign the throttle sleeve, and generally gumming up the plastics, no injury to anything metal on the frame or engine ie no rash on the case cover.
So heres the question for you guys, after i took apart the bars I cannot get the clutch to disengage, I can find neutral and she starts and runs just fine but cannot get her to disengage so when I am in a different gear the wheel more or less locks, so in the quest to get the clutch working again I pulled the case cover apart pulled the springs, and plates and puller wiped down and relubed everything. then put it all back together filled her up with oil etc etc. still to no avail my thoughts are it may be the cable? or does it sound to you guys like something even more involved like the clutch mechanism itself.
on another note does anyone have harris performance rearsets? I am trying to figure out how to attatch the springs to everything and the instructions give no hint or placement.
Thanks a lot for your help guys
