HELP with Scorpio Alarm
Old Mar 26, 2008 | 12:46 PM
bieniu's Avatar
Registered Users
Default HELP with Scorpio Alarm
I bought a Scorpio alarm system the IS-500 and came to a conclusion that i cant find a spot to put it in ,is there any one that has one and can tell me where they placed the main unit or have pix of it how the got it set up (note that i have a PC 3 under my rear seat). I tryied under the front seat but it dont fit .
Old Mar 26, 2008 | 03:51 PM
Raptorsj's Avatar
Default RE: HELP with Scorpio Alarm
I have a 2007 RR and put it under my seat. I'll take pix if you'd like. Let me know.
Old Mar 26, 2008 | 04:18 PM
Xx New Guy xX's Avatar
I'm not sure if you have room on an RR - but on an F4i there is room if you take off your tail and slide it in there - you may also be able to hide it under the fairings...
Old Mar 26, 2008 | 04:34 PM
OKIEZAC's Avatar
ORIGINAL: Raptorsj
please take pics.. i would like to see how you did that.. take as many as you can please..
thanks.
Old Mar 26, 2008 | 04:52 PM
ina6r's Avatar
ORIGINAL: Raptorsj
Pics would be great. I also have an 07RR and just got the i900. I'll need to figure out where to put it. Thanks!!!
Old Mar 26, 2008 | 09:49 PM
bieniu's Avatar
Registered Users
i tried to put it under the front seat but it sticks out to much because of the battery and the seat has that plastic under it and the mold has that plastic hook type thing that holds the seat and thats whats in the way
Old Mar 27, 2008 | 02:12 AM
azncupid22's Avatar
i installed mine back in january. i put the main module under the seat. it's not goin to fit exactly in the center. you're going to have to mount it on the side, where it sorta slopes downward. the permiter sensor is mounted under the seat, i just found a place where it would mount and be stable. the antenna, well i sorta improv'd on that one. i just let it stick out when i put the seat back on. the more straight up the wire is, the better reception, so it jus sticks out a bit from my seat, like 1mm.
Old Mar 27, 2008 | 10:23 AM
Raptorsj's Avatar
I did it pretty much like cupid. It fits nicely (but tightly) on the right side. The extra wires are under the back part of the tank and the sensor is under the battery strap. I just stuck the antennae under the battery strap also.
http://i175.photobucket.com/albums/w...j/DSC00497.jpg
BTW, the extra cord at the top is a battery tickler that I can get to with the seat on.
Hope this helps. Essentially, it does fit!
Old Mar 27, 2008 | 10:53 AM
bieniu's Avatar
Registered Users
the pic u got there is that 2007 or 2006 ?
Old Mar 27, 2008 | 01:55 PM
Raptorsj's Avatar
2007
