REplaced grips and they dont fit!!!
Old Oct 10, 2007 | 07:49 PM
20HNDAF4i02's Avatar
Default REplaced grips and they dont fit!!!
I put them on last night and waited for the glue to dry. When i put the bar ends on the grips are about 1/2 an inch too small.[:@] What the hell????THey said for a 2002 f4i!!! Is there anything i can do .....besides buying new ones!!
Old Oct 10, 2007 | 09:10 PM
alekinci's Avatar
Default RE: REplaced grips and they dont fit!!!
may be you should have place the grips on the bars before applying the glue. you know, just to make sure that they would fit.
i hope the next set you have is a better fit.
Old Oct 10, 2007 | 09:29 PM
Thats kind of hard to do when they dont just slide on and off!!
Old Oct 10, 2007 | 10:04 PM
ta8218's Avatar
You blow compressed air between it and the bar and it goes on and comes off like butter. Once the air goes away it wont move.
Old Oct 11, 2007 | 02:08 PM
06F4IMike's Avatar
i had the same thing with my first set. Ends up they were off road grips but i didnt have them glued on. So they went on my dirtbike and i had to get another set!
Old Oct 11, 2007 | 03:02 PM
Tahoe SC's Avatar
as long as they go where you hand goes...it's all good...but it may look fugly...but it still works!
functionality > looks...
Old Oct 12, 2007 | 07:56 PM
richhowerton's Avatar
You just get to buy another set. Next time fill the grip with water and soap they will slip on and off to test the fit. then you just dry off the soap and wet the grip and it will slip on. Old golf club trick.
Old Oct 13, 2007 | 02:48 PM
stevelive3's Avatar
hairspray works the best, spray inside, slide grips on, set them where you want and they are ready to ride within a minute.
speeddemonx60
Feb 7, 2010 11:02 AM
jaynd
Oct 2, 2008 02:33 PM
stinger95
Nov 20, 2007 03:40 PM
james007torres24
Jan 30, 2007 08:35 PM
jaghunter
Dec 16, 2006 01:44 AM
