REplaced grips and they dont fit!!!
Old 10-10-2007 | 08:49 PM
20HNDAF4i02's Avatar
Default REplaced grips and they dont fit!!!
I put them on last night and waited for the glue to dry. When i put the bar ends on the grips are about 1/2 an inch too small.[:@] What the hell????THey said for a 2002 f4i!!! Is there anything i can do .....besides buying new ones!!
Old 10-10-2007 | 10:10 PM
alekinci's Avatar
Default RE: REplaced grips and they dont fit!!!
may be you should have place the grips on the bars before applying the glue. you know, just to make sure that they would fit.
i hope the next set you have is a better fit.
Old 10-10-2007 | 10:29 PM
Thats kind of hard to do when they dont just slide on and off!!
Old 10-10-2007 | 11:04 PM
ta8218's Avatar
You blow compressed air between it and the bar and it goes on and comes off like butter. Once the air goes away it wont move.
Old 10-11-2007 | 03:08 PM
06F4IMike's Avatar
i had the same thing with my first set. Ends up they were off road grips but i didnt have them glued on. So they went on my dirtbike and i had to get another set!
Old 10-11-2007 | 04:02 PM
Tahoe SC's Avatar
as long as they go where you hand goes...it's all good...but it may look fugly...but it still works!
functionality > looks...
Old 10-12-2007 | 08:56 PM
richhowerton's Avatar
You just get to buy another set. Next time fill the grip with water and soap they will slip on and off to test the fit. then you just dry off the soap and wet the grip and it will slip on. Old golf club trick.
Old 10-13-2007 | 03:48 PM
stevelive3's Avatar
hairspray works the best, spray inside, slide grips on, set them where you want and they are ready to ride within a minute.
speeddemonx60
02-07-2010 12:02 PM
jaynd
10-02-2008 03:33 PM
stinger95
11-20-2007 04:40 PM
james007torres24
01-30-2007 09:35 PM
jaghunter
12-16-2006 02:44 AM
Quick Reply: REplaced grips and they dont fit!!!
