Removing side tail reflector mounts
Old Mar 28, 2012 | 07:53 AM
kdbolt70's Avatar
Default Removing side tail reflector mounts
These things are riveted on and look kind of goofy now that I've installed my fender eliminator. Anyone have a good way of removing them?
Old Mar 28, 2012 | 09:13 AM
74demon's Avatar
unfortunately, since theyre riveted you have to leave them on. sorry....
just kidding, drill or grind off the head of the rivet. the bracket will fall right off.
Old Mar 28, 2012 | 09:47 AM
Incompatible's Avatar
Easy enough to drill out the rivets and remove the reflectors. Be carefull to remove only the rivet heads and then punch out the shaft. Save the reflectors should you wish to replace later by installing new rivets. As Demon mentioned, you can also grind the heads off if saving the bracket is not a concern.
Old Mar 28, 2012 | 10:12 AM
kdbolt70's Avatar
Thanks guys, I figured as such. Rivets are a pain for such a little piece.
Also, on a somewhat unrelated note, has anyone found anything better than the plastic screw clips used to hold the front 'V' fairing to the side fairings? Man those things suck...
Bordo
How To's
Sep 26, 2012 03:01 AM
Riderc82
Dec 7, 2008 10:21 PM
JVracer04
Sep 28, 2006 09:51 PM
ride_002000
Jun 5, 2006 04:48 AM
rrasco
May 5, 2006 12:58 PM
