Removing Fuel Tank
Old May 16, 2007 | 05:04 PM
Gizmo's Avatar
Default Removing Fuel Tank
Im just curious but how do you remove the fuel tank?
Ive got all the bolts out and the wires disconnected, but the hoses have me baffled.
thanks.
BTW: this is an 2001.
Old May 16, 2007 | 06:32 PM
woodyracing's Avatar
Default RE: Removing Fuel Tank
sit a bucket under the fuel pump, unbolt the main fuel line (its either 14 or 17mm)
the others you just pull off (the other one going into the fuel pump has a clip on it just squeeze that with a pair of pliers)
the F4i doesn't have a petcock so make sure you get all the fuel out of it you can before disconnecting the main hoses
you can pinch the lines to keep fuel from coming out of that end but it'll still come out of the tank so have a bucket underneath and a lot of rags just in case
Old May 16, 2007 | 07:02 PM
therabbit's Avatar
In case you didn't know check out StephyGee's site, it has availible downloads of the service manuals.
pookguy88
Nov 4, 2023 06:12 PM
dc519
Oct 11, 2010 08:08 PM
yog182
Jan 20, 2010 05:30 PM
mnguyen84
Apr 16, 2009 07:38 PM
rrasco
Mar 15, 2006 07:09 PM
