Removing Fuel Tank
Im just curious but how do you remove the fuel tank?
Ive got all the bolts out and the wires disconnected, but the hoses have me baffled. thanks. BTW: this is an 2001. |
RE: Removing Fuel Tank
sit a bucket under the fuel pump, unbolt the main fuel line (its either 14 or 17mm)
the others you just pull off (the other one going into the fuel pump has a clip on it just squeeze that with a pair of pliers) the F4i doesn't have a petcock so make sure you get all the fuel out of it you can before disconnecting the main hoses you can pinch the lines to keep fuel from coming out of that end but it'll still come out of the tank so have a bucket underneath and a lot of rags just in case |
In case you didn't know check out StephyGee's site, it has availible downloads of the service manuals.
