Removing tank bra...
The bike came with a Lockhart Phillips Glasmask 1/2 tank bra, and I was wondering how to remove it. At first I thought the elastic part was just wrapped around and under but it seems like I have to remove some bolts. I am thinking of just cutting it off, but would rather keep it in one piece. I tried searching for a install pdf but came up with nothing.
Thanks.
Thanks.
First step would be to remove the two air intake covers that are next to the tank, then remove the four main bolts holding the tank to the bike. That will allow you to lift it up enough to see how the bra is held down underneath. More than likely that'll be all you'll need.
