Question about changing brake pads?
I have a brake bleeding/vacuum test pump kit, just hook it to the bleed nipple, open it, and pull the fluid through....just make sure you dont empty the resevoir. You can get a similar kit at your autoparts store pretty cheap. called a 1 man bleed kit. just pull fluid until it is clear coming through the hose.
