Problem taking off rear smingarm????
Old Feb 5, 2008 | 04:58 PM
slvr600's Avatar
Default Problem taking off rear smingarm????
I have a 2002 f4i, and am wanting to take the swingarm off and drop the engine to replace the clutch. The question i have is does anyone know where i can find the tool used to take off that nut that holds the collar that goes thru swingarm and transmission? It looks like a certain kind of socket that is almost like a key? Any help would be appreciated
Old Feb 5, 2008 | 08:59 PM
F4Isvt's Avatar
Default RE: Problem taking off rear smingarm????
i am assuming your taking about the one with 4 tabs in a X pattern. if so make one if you have access to a bridgeport or a good cut/off wheel. I did it with a socket cant remember what size but try them in there till you get one fairly snug mark the socket and cut away.
Old Feb 5, 2008 | 09:26 PM
slvr600's Avatar
alright ill give it a try, thanks man.....
Old Feb 5, 2008 | 11:12 PM
Jaybird180's Avatar
Dude, you don't need to do that to change the clutch. Clutch is on right side, just remove fairings.
romanboy
Jan 6, 2013 07:57 PM
jlf51483
Sep 22, 2009 01:07 PM
FlashBazbo
Jul 3, 2008 08:30 PM
de goose man
Apr 4, 2007 02:38 PM
