Any problem taking off rear pegs?
Old 07-02-2008, 01:49 PM
FlashBazbo's Avatar
Default Any problem taking off rear pegs?
I have a 2007 CBR600RR and it seems to me a very quick and easy way to lose some weight and clean up the rear end is to remove the rear pegs and brackets. Two downsides I can see: (1) no protection for the rear brake reservoir, and (2) removal will leave unsightly holes and indentations in the frame.
I don't plan to carry a passenger ever. Are there downsides I haven't thought about? Has anyone done this? How ugly are the holes/indentations with the brackets removed? Is there a cosmetic fix for those?
Old 07-02-2008, 02:15 PM
Default RE: Any problem taking off rear pegs?
you wont have any problems with the brake reservoir, I have a 600rr 2005 and you can't even notice the holes on it. on your year/model you shouldn't be able to really tell anyways, but its up to you. I hated having the rear pegs on, so those and a seat cowl and it'll look pretty pimp.
shoortbuss's Avatar
Are you really convinced it will make a big difference weightwise? I gain or lose more weight in a day than removing those pegs will do. Still, lots of people do it to clean up the look.It really would have only taken a few minutes for you to find out what it's going to look like and then put them back on. Sorry for the ranting, I'm cranky this week.
Anyways, it's not going to be bad looking at all. Nobody will even notice the holes. If you don't like them, then just put the bolts by themselves back in. Problem solved. If you're going to do it, then you might as well go ahead and get the rear cowl.
Old 07-02-2008, 02:20 PM
+1 on putting the bolts back in, never thought of that. do they stick out?
Old 07-02-2008, 05:03 PM
na they shouldnt.
plus if your really into cleaning it up im pretty sure they make a block off kit. i have seen them on ebay.
altho, anything you get on ebay is a gamble. it might not even fit [:-]
Old 07-02-2008, 05:46 PM
heybuddy1901's Avatar
just put the bolts back in.
i rarely carry a passenger, but when i do it takes 2 sec to put the pegs back on..
pegs removed:
Old 07-02-2008, 09:44 PM
FlashBazbo's Avatar
I took the pegs off this evening. One slight glitch is that the brake line coming from the reservoir is attached to the right-side bracket. Not an insurmountable issue, but it will require finding something else to anchor it to. (It will flop around otherwise.)
I've got the seat cowl on order.
Old 07-02-2008, 10:06 PM
mine doesnt flop, its actually really stable.
but this problem will soon be solved with a g-craft replica resivor which mounts to the back of the rear M/C and gets rid of all that crap.
Old 07-02-2008, 10:13 PM
redbbwoy's Avatar
wtF?! lmao...y wudnt u think of puttin the bolts back in?!
but yea ii removed mine 2 clean up looks!! n ii put em onif ii kno iima have a bitch(FEMALE-sry ladies) on the bak!!
CHA DIGG?
Old 07-02-2008, 10:47 PM
TK954RR's Avatar
Jan 2009 ROTM
Uhh ziptie anyone
How do you guys do staggered standups without rear pegs
Quick Reply: Any problem taking off rear pegs?
