Problem please help.
Old Nov 23, 2007 | 10:27 AM
bwayers's Avatar
Default RE: Problem please help.
ORIGINAL: Aken
You've got a serious problem where a positive wire is making constant contact with a piece of metal, creating a spark and inevitibly causing something to burn (the cause of the smoke). You should try and source the problem IMMEDIATELY.
sounds like your problem right there
if you're still under warranty take it back to the dealer and make them fix it
Old Nov 24, 2007 | 07:44 PM
inkredibleg's Avatar
Hey guys so I found out what the problem was. I just recently bought front led signals, There was some type of resistors on the positive wire. So the resistors on both sides turned into charcoal, and that made the fuse to go boom. So now I re-wired everything without the resistors made the led's work as turn only not running lights and replaced the fuse, Now they seem to work fine. Thanks for your suggestions though.
kwood
Jun 1, 2020 09:53 AM
hatchtegman
Sep 1, 2010 03:15 PM
vietladin
Dec 25, 2007 09:48 AM
dewthedoo05
Sep 4, 2007 09:32 PM
Trips
Nov 26, 2006 01:45 AM
