overheating issues plz help
Old Jun 21, 2010 | 01:56 PM
V'SKUSTOMS's Avatar
Default overheating issues plz help
I have a 04 cbr f4i 600 with 14,000 miles, it just started to overheat on me at a stop light. this is what i have checked so far, did a coolent flush and added new coolent,checked radiator for leakes flushed and cleaned raidaitor, checked water pump works fine, checked thermostat took it out boiled it and it opens, checked fan works good and kicks on at 220. out of ideas what else can it be?
Old Jun 21, 2010 | 02:53 PM
thirdgenlxi's Avatar
Ironmang
How hot is it getting?? And did you burp the cooling system real good?? Have you looked at the actual fan blade itself to make sure it's spinning?? Sometimes they break right in the middle where it bolts onto the shaft of the motor, and the motor will spin but the blade won't
What kind of coolant are you using?? Stock green stuff, or something aftermarket like Engine Ice??
Old Jun 21, 2010 | 02:57 PM
V'SKUSTOMS's Avatar
yes i burpped the system, checked the fan blades works fine, and using aftermarket coolent engine ice. what else can it be
Old Jun 21, 2010 | 03:11 PM
Sick97SS's Avatar
Looks like you've checked everything, unless there is a clog deep in the radiator i dont know. As asked,,, how HOT is it getting?? On a hot day stuck in traffic mine will get to 225 -230 degrees. Yea my crotch is on fire but its not overheating.
F4is will throw a warning light and shut off when they are overheating. (240 degrees i think)
Old Jun 21, 2010 | 03:18 PM
V'SKUSTOMS's Avatar
gets up to 250- 270 coolent spills out and temp lights comes on
Old Jun 21, 2010 | 03:37 PM
Sick97SS's Avatar
The bike is supposed to shut-off to prevent damage after 252 so it sounds like a clog somehere unless you use the wrong coolant..
Old Jun 21, 2010 | 04:22 PM
Ironmang
Ohhh I C.... so did you -COMPLETELY- flush the cooling system with distilled water multiple times to get ALL of the old coolant out?? Cuz you know if Engine Ice and ethylene glycol antifreeze mix, it gels....
What temp is it running at going down the road??
Old Jun 24, 2010 | 12:01 AM
V'SKUSTOMS's Avatar
thanks guy's this worked, flushed it a couple more times using the distilled water and back on the road
Old Jun 24, 2010 | 06:10 AM
usetheffours's Avatar
Well I learned something today
Old Jun 24, 2010 | 08:30 AM
Ironmang
Excellent!! Glad to hear you're back on the road
6rush6
Jul 8, 2024 08:23 AM
freddieb
Jan 21, 2014 06:06 AM
PM289
Apr 2, 2012 12:29 PM
Dblock55
May 9, 2011 10:42 PM
bigboi18184
Feb 4, 2010 11:42 AM
