Oil Leaking
Old 12-31-2007, 10:21 AM
Lamar Vannoy's Avatar
Default Oil Leaking
Took my farings off over the weekend and found some evidence of oil leaking on right side by the clutch cover. I bought the bike in Oct w/ 5100 miles on it.
Has anyone else had this or know where it might be coming from?
Old 12-31-2007, 12:27 PM
Default RE: Oil Leaking
My guess is that brass colored allen "plug". That or the clutch cover itself.
Old 12-31-2007, 01:31 PM
My Guess is inbetwen the 3rd and 4thbolt starting from the bottom of the pic. try replacing the gasket. that is where i would start
Old 12-31-2007, 05:21 PM
ConeyIsland#1's Avatar
ORIGINAL: TBFGhost
+2 im thinking of the same thing.
Old 12-31-2007, 08:19 PM
Stephens's Avatar
Try tightening the bolts first
Old 01-01-2008, 12:22 PM
Jaybird180's Avatar
Torque the bolts as Stephens said. Clean everything up so you can see where it's leaking from when you run the engine. I once had a hairline crack in the metal of my stator cover that would only show after a ride. Don't forget to check your oil level before you run the engine.
Monkeybutt2000
05-28-2011 08:54 PM
12Pack
11-03-2008 09:39 PM
gmario1000kRR
12-24-2007 08:33 PM
Lanphe1r
07-23-2007 09:39 PM
907hondaf3
03-24-2006 02:32 AM
Quick Reply: Oil Leaking
