Oil Leaking
RE: Oil Leaking
Torque the bolts as Stephens said. Clean everything up so you can see where it's leaking from when you run the engine. I once had a hairline crack in the metal of my stator cover that would only show after a ride. Don't forget to check your oil level before you run the engine.
