Off the wall frame slider Question
Old Sep 30, 2008 | 12:21 AM
Alexlittle's Avatar
Default Off the wall frame slider Question
I took the body off my bike, put it back together and now have no spark. The only thing I did take off was a bent frame slider. Does the bolt that holds it on contact a ground or sensor or something.? I know it sounds stupid, but I cant figure out what else it would be, everything else is normal.
Old Sep 30, 2008 | 12:49 AM
brakeswhatbrakes's Avatar
Default RE: Off the wall frame slider Question
did you take your upper fairing off an forget to plug in your BAS? if not i would check all my connections an make sure nothing is loose or pinched
Old Sep 30, 2008 | 12:53 AM
Alexlittle's Avatar
I bypassed the bas.
Old Sep 30, 2008 | 01:14 AM
id go back an check all your jumpers then. when you turn it on can you hear the fuel pump turn on if not you have your BAS bypass wired wrong.
tomp
Oct 27, 2008 09:46 PM
YellownBlack
Sep 17, 2007 12:05 AM
BaseballPlayer
Apr 9, 2007 03:11 PM
rockhardclimbr
Sep 15, 2006 07:40 AM
Geekster47
Apr 11, 2006 11:39 PM
