Another Frame Slider Question
Old Apr 10, 2006 | 11:56 PM
Geekster47's Avatar
Default Another Frame Slider Question
I picked up my new Red/Black CBR1000RR two weeks ago. Still looking for frame sliders help. Has anybody installed any brand on their 06 yet? Are they the no cut version (offset bracket), or was cutting the fairing necessary (direct bolt on)? I want the strongest brand out there (less bending or breakage in the event of a crash). I am willing to cut if necessary. Previous posts said that the offset bracket models can cause water pump damage in the event of a left side crash. Let me know what fits and your recommendations.
Old Apr 11, 2006 | 01:01 AM
RedRider79's Avatar
Default RE: Another Frame Slider Question
u can use the 05 lockhart philips if you need them on the bike asap, but you'll need to use a collar to take up some of the space in between the fairing and the frame.
im still waiting on the 06 ones to come off backorder.
Old Apr 11, 2006 | 11:39 PM
hobbs51's Avatar
i used the type that you have to cut the fairing because of the water neck issue 15 hours labor dropping the motor you can by 2 sets of fairings for that kind of money. i set by bike on a rear stand took the fairing off then used a camera tripod to mount a laser pointer on and shot the bolt in the center with the laser replaced the fairing and let the laser mark the spot to drill. the only thing bolt the fairings all the way up before shooting the laser or your drill hole will be off. after the i took a magic marker after i installed the slidder and marked around the slidder to get about a 1/4" clearance so the fairing would not be viberating and crack works well . the only hang up you will have to cut into the gromet on the left fairing where the bolt holds the fairing at the top hole.
tomp
Oct 27, 2008 09:46 PM
csfirsthonda
May 30, 2008 04:02 PM
YellownBlack
Sep 17, 2007 12:05 AM
rockhardclimbr
Sep 15, 2006 07:40 AM
Whitby_F4i
Jun 24, 2006 07:59 AM
