frame slider question
Old Sep 7, 2006 | 09:15 PM
rockhardclimbr's Avatar
Default frame slider question
Just wanted to get some input on what frame sliders I should put on a 2006 CBR600RR. Thanks.
Old Sep 12, 2006 | 01:46 AM
Blue Fox's Avatar
Retired Moderator
Default RE: frame slider question
I have frame sliders on my new 06 600rr. They are a plastic like material, and originally, I wanted to replace them because I couldn't believe that this light feeling plastic would protect my bike. Well, a few days ago while visiting my parents, my dad backed into my bike and knocked it over on its side. The slider held up and buckled slightly, absorbing the brunt of the impact.....nothing damaged except for a little scuff on my mirror.
No matter what slider you put on, you are going to have to drill a hole through the fairing. (which sucks to line up right). I suggest taking it to a dealer to do it. So if they mess up, they have to replace the fairing. My dealer only charged me 50.00 to install them, and it was perfect.
I can't remember what brand they were though. They were pretty generic looking. I'll let you know if I find out what they are.
Old Sep 12, 2006 | 05:54 AM
ok cool. i'll find out what my dealership would charge. 50 bucks is the worth the labor you'd put into it urself. and if u **** up, ur screwed.
Old Sep 12, 2006 | 02:37 PM
MisterBasket's Avatar
I got vortex sliders on my bike and I like them alot. I did it myself. Its not as bad as people make it out to be as long as you have patience and take your time. Someone posted a frame sliders how to in the do it yourself section I think.
Old Sep 12, 2006 | 02:58 PM
unrealtrip's Avatar
Spring loaded sliders are the only ones that make sense IMHO. Traditional sliders will absorb some of the impact just because they are plastic, but the brunt of the force is transferred directly into the frame of your bike. Personally, I'd rather lose my fairing than risk tweaking/twisting my frame. Bad Phish spring loaded sliders are the way to go.
edit: http://www.badphish.com/
As far as installing them, the simple way to perfectly line up the hole is to use a laser level. There are many explanations if you do a search, but more or less with the level on a tripod or stepstool or something, you line it up with your fairings off so that that the laser level beam is pointed directly at the bolthead you will remove to install your sliders. Put the fairing on, mark the spot where the light is, remove and hole cut.
Old Sep 15, 2006 | 07:40 AM
vasta101's Avatar
I have Intuitive Sliders and they work great... some people have complained about some slider bolts breaking on impact but mine did their job...
tomp
Oct 27, 2008 09:46 PM
csfirsthonda
May 30, 2008 04:02 PM
YellownBlack
Sep 17, 2007 12:05 AM
Whitby_F4i
Jun 24, 2006 07:59 AM
Geekster47
Apr 11, 2006 11:39 PM
