is this normal?
Old Jan 23, 2012 | 02:56 PM
omg209's Avatar
Default is this normal?
i have a cbr 600 f4i 2002 got it 2 weeks ago
when i start my bike it takes about 5 to 10 tries to start the bike where it will run and warm up at around 3k rpm and drop normally
i also have the FI light always on, no matter what. it does not blink it just stays on when starting the bike and riding it, it will not go away. Everything else about the bike seems fine.
i would also like to know what is the recommended operating temperature after warming up the bike and get it ready for riding.
Old Jan 23, 2012 | 03:09 PM
74demon's Avatar
the FI light is not supposed to be on. it is your computer's way of telling you that something is not right. do you have a service manual? it sure would help. you need to locate the diagnostic connector, its a two wire connector that sticks out of the main harness under the seat, jump it with a paper clip and count the blinks of the light. that will give you a code that will help point you, and us, in the right direction.
Old Jan 23, 2012 | 03:34 PM
omg209's Avatar
will do, i will do that right now. ill get back to you soon i hope.
Old Jan 23, 2012 | 03:56 PM
omg209's Avatar
so i turn my key to on, i am reading 7 blinks. ECT sensor?
Old Jan 23, 2012 | 04:23 PM
Kevwa451's Avatar
^ what he said, and as for regular operating temperature it's about 180 +/- degrees. I usually just wait until my idle drops until I set off on a ride. So usually 110-120 degrees is what I let it warm up too before I ride it. But that all depends on the temperature outside. If it's 70+ degrees out I'll let it idle for maybe 15 seconds and then take off. I just keep the RPM's low until it's warmed up.
Old Jan 23, 2012 | 04:39 PM
Aken's Avatar
July 2008 ROTM
I usually let it warm up until the temp gauge says a number, instead of "--". Then I take off, keeping it easy until it's up to a more normal operating temp.
Old Jan 23, 2012 | 10:37 PM
omg209's Avatar
thanks for the responses, i got it fixed. took a few hours with all that cramped space. a rat chewed one of the wires off. had to resolder wires together, no more FI light yay!
Old Jan 23, 2012 | 11:31 PM
An01InAZ's Avatar
Fuel pressure regulator, possibly for starting on 10th try. And not the first. Thats what mine was doing til I replaced it
MT Wallet
Aug 2, 2008 12:43 AM
minur505
May 11, 2007 04:08 PM
FiremanE4
May 5, 2007 06:33 PM
danny600rr
Dec 14, 2006 09:57 PM
drksidr
Apr 28, 2005 07:21 AM
