safest max octane ?
Old Jan 18, 2012 | 10:02 PM
02TrickFlowGT's Avatar
Default safest max octane ?
Hey, got a buddy whos got some real high octane race fuel, cant remember what octane but it was over 113, whats the highest octane you can run in an F4i safely, not sure about bikes but in a car that is not built for it too high of octane can destroy valves and burn the motor up and stuff, Think they run it in their track bike, its a pretty modded Busa but i have alot at my convinence if i wanted it so just wondering if thats safe for my bike?
Old Jan 18, 2012 | 10:09 PM
FLATBLACK740's Avatar
what is your motive? as u will more than likely b losing power, higher oct. is much harder to burn unless ur motor is tuned for it!
Old Jan 18, 2012 | 10:12 PM
yeaahh i was worried about that:/ well in that case what octane (for future reference) will get me the most usefull power without harming my bike? just has full exhaust no other mods, be looking into a power commander soon but thats a diff story
Old Jan 19, 2012 | 11:03 AM
chambers's Avatar
The manual calls for 87 octane, running 89, 91, 93 won't do any harm though except for costing more at the pump.
Old Jan 19, 2012 | 11:54 AM
R Dub's Avatar
October 2011 ROTM
Run 87 in the F4i. Any more and you're losing performance and money.
Old Jan 20, 2012 | 12:12 AM
boredandstroked's Avatar
You have no idea what your saying. Too LOW of an octane can burn the motor up, going higher then needed will carbon foul the motor eventually. As said above use 87 octane.
Old Jan 21, 2012 | 09:13 AM
speedyf4i's Avatar
I use 91 in my f4i. Shell nitrogen enriched gasoline for the win haha
Old Jan 21, 2012 | 10:14 AM
R Dub's Avatar
October 2011 ROTM
Using 91 in the F4i really is a waste of money and lowering performance. Here is an article that talks about octane ratings.
RON = Research Octane Number (what the bike/manual says)
PON = Pump Octane Number (what you see at the pump)
90 RON = 86.6 PON
92 RON = 88.5 PON
95 RON = 91 PON
96 RON = 92 PON
98 RON = 94 PON
PETROL
After millions of years of heat and pressure, a pile of dead trees and plants buried deep in the earth gets broken down and transforms into crude oil. (ed. This is an entirely different discussion with many different views) Sooner or later, a fat Texan pumps it out of the ground, then refines and separates the stuff down to its constituent parts. And every hundred miles or so, you fill up your bike's tank with one of the liquids produced as a result.
The clear fluid we know as petrol (ed. That's what the Brit's refer to "gas" as.) is a combination of different hydrocarbons - compounds of hydrogen and carbon elements - ranging from seven to 11 carbon atoms in length. Mostly, it's octane (the hydrocarbon with eight carbon atoms). Petrol contains huge potential energy - a gallon contains the equivalent of 31 million calories (or, in food terms, 63 Big Macs).
But this energy needs to be released. That involves mixing the petrol with air and squirting it into an engine's combustion chamber to be ignited by the spark from the plug. The theoretically perfect mix of air:fuel is 14.7:1 (known as the 'stoichiometric ratio'). Under these conditions, the hydrocarbons burn completely. Hydrogen atoms join with oxygen atoms, creating H2O (water) and all the carbon bits turn into CO2 (carbon dioxide). In practice it never happens that perfectly, thanks to the presence of other contaminants in fuel and air, but that's the idea at least.
Before the spark plug sparks, this mix of air and fuel is compressed by the piston's compression stroke. Cars typically run a compression ratio of about 8:1 (squashing the gas into an eighth of its volume). Bikes run much higher ratios to generate more power: the relatively gentle Suzuki SV650 runs at 11.5:1 and the monster Kawasaki ZX-10R at 12.7:1.
The problem with high compression ratios is that heptane (one of the hydrocarbons found in petrol) doesn't react well when it's squashed. Its molecular bonds are weak, so compress it a little and it ignites spontaneously. The bonds in octane are far stronger, so it takes much more compression before it ignites. This is why tuned engines are run on high-octane petrol.
WHAT DO OCTANE RATINGS MEAN?
At the petrol pumps you're often faced with two types of unleaded - regular (95 RON) or super (with a higher value). RON stands for Research Octane Number, a measure of how resistant the fuel is to igniting under compression.
A fuel of 95 RON, such as regular unleaded, has the same resistance to compression as a mix of 95 per cent octane and 5 per cent heptane. Fuels of more than 100 RON are made by adding chemicals that are more resistant than octane. Shell Optimax claims a 98 RON rating; BP Ultimate Unleaded is 97 RON.
Octane alone won't increase power. It only allows the potential for an engine to run a high compression ratio - and that's what will increase power. Run a high-compression engine on low octane fuel and detonation occurs - and that can destroy a motor.
WHAT IS DETONATION?
Detonation - also known as knock - occurs after the spark plug has sparked. The spark starts a flame in the middle of the cylinder, which should spread out to the edges with a single flame front. But if gas at the edges of the cylinder ignites (due to high temperature or pressure) before the flame meets them, it causes multiple flame fronts in the cylinder. When these collide they create a sharp rise in heat and pressure. Occasional, slight detonation isn't a problem but constant, severe detonation will wreck an engine.
Some bikes, like BMW's extremely high compression K1200S (13:1) use a knock sensor. This detects frequencies in the cylinder and, if it registers those associated with knock, tells the engine management system. This then retards the ignition advance (how far ahead of the piston reaching Top Dead Centre the spark plug fires). Ignition advance is necessary because petrol takes time to burn, so igniting the mixture when the piston is already at the top of its travel is a waste of energy. As revs increase, the piston speeds up so more advance is needed. Retarding the amount of advance will reduce power but lowers temperature and pressure, reducing the conditions that cause knock.
HOW IS RACE FUEL DIFFERENT?
Contrary to popular belief, race fuel isn't super-high-octane juice. FIM regulations for MotoGP and Superbikes only allow fuels between 95 and 102 RON - not a world apart from the octane of petrol we buy at the high street pump. In fact, race teams want to use the lowest octane fuel they can get away with, as a side effect of high octane is slow combustion.
The big difference between race fuel and road petrol is that fuel companies work closely with race teams (such as Shell Advance with the Ducati GP team) to develop a bespoke (ed. That means custom-made, btw.) fuel for a specific bike's demands, which change from day to day. Pump unleaded has to work in a variety of vehicles and conditions. So nicking a drum of Desmosedici fuel for your road-legal 999 won't magically increase its power.
USE YOUR KNOWLEDGE (SIDEBAR)
So what should you fill up with? Simple. Assuming you haven't changed your compression ratio, run your bike on what the manual tells you to. In the case of most road bikes, that's standard 95 RON. Extra octane won't increase power - it really is just a waste of money. If the book asks you to run it on higher-octane fuel then stick to it rigidly, unless you have a knock sensor - like BMW's K1200S or new R1200 models. In this case, if you want to save a few quid and don't mind losing some bhp, you can use regular. You're safe to mix and match regular and super, too.
In summary, running a higher compression ratio is what gives more power. Higher octane gas by itself does not.
Old Jan 21, 2012 | 12:54 PM
speedyf4i's Avatar
hmmm i was unaware the bike could take 87 as i dont have a manual. I was told bikes should run 91 since they have a higher CR than most daily driven cars. If ive been using 91 can i just switch back to 87 on the next tank?
Old Jan 21, 2012 | 01:19 PM
supersnake83's Avatar
Yes, you can just switch back on your next fill up.
I have also tried different octanes in my bike and have tried 87, 89, 91, and 93. I can't remember if it was Sunoco that I saw 94 once and tried it, but eventually, for my bike, running 87 yielded the best power and gas mileage.
