Need help
Ok long story.. my bike would randomly die on me while riding and to get it going again I'd have to turn the key off then back on and she'd fire back up. I was trying to see why and under the headlights there is a electrical flasher relay that had the wires that connect to the plug almost torn in half. So I tried fixing the wires in doing so destroyed the plug that goes into my relay but I connected a couple female pieces and plugged it back in. But my fuel pump will no longer prime and brights don't work. Everything else seems to be fine and once in a while my fuel pump primes but sounds really weak. I hope somebody can point me in the right direction because I am lost.
Is it the 12 pin connector thats gone west, as the Bank Angle Sensor runs through that connector and will stop the pump running, if so go back to that connector and make sure connections are being made
jarhead89x
Sep 26, 2008 09:38 AM
mattyggstick
Jun 20, 2008 09:22 AM
