Need help
Old May 20, 2018 | 12:45 AM
Supahfly's Avatar
Default Need help
Ok long story.. my bike would randomly die on me while riding and to get it going again I'd have to turn the key off then back on and she'd fire back up. I was trying to see why and under the headlights there is a electrical flasher relay that had the wires that connect to the plug almost torn in half. So I tried fixing the wires in doing so destroyed the plug that goes into my relay but I connected a couple female pieces and plugged it back in. But my fuel pump will no longer prime and brights don't work. Everything else seems to be fine and once in a while my fuel pump primes but sounds really weak. I hope somebody can point me in the right direction because I am lost.
Old May 20, 2018 | 06:44 AM
CaBaRet's Avatar
Is it the 12 pin connector thats gone west, as the Bank Angle Sensor runs through that connector and will stop the pump running, if so go back to that connector and make sure connections are being made
dr.squid
Jan 28, 2018 04:42 AM
jarhead89x
Sep 26, 2008 09:38 AM
mattyggstick
Jun 20, 2008 09:22 AM
the greeen lantern
Jul 13, 2007 09:19 AM
