Mosfet REG/REC charging
Old 07-01-2018, 05:49 PM
WendellB's Avatar
Default Mosfet REG/REC charging
So the Mosfet regulator they say will plug and play with CBR 6004fi there seems to be an issue with the wiring. My harness plugs into the stator and then the battery terminals plug into the same general area. The Mosfet has wires going to the battery. What gives?
Old 07-11-2018, 07:54 PM
WendellB's Avatar
So I just installed a mosfet rectifier/regulator on my Honda CBR 600 4fi but have some concerns. When running my bike at 5000 rpms the voltage output does not go above 13.3 volts. I was expecting 14.0 volts and wonder if I can trust this unit to keep me going. Does the Mosfet not produce as high voltage when the battery is fully charged? Seems it should. I check the stator and it is not open on any of the three posts and neither is there a short to ground anywhere. The plugs seem to be in all the way as they clip together. Voltage of the battery is 12.6 and there is some output at 13.3 volts is this just an anomaly of the Mosfet? Thanks for your time.
Old 07-12-2018, 01:15 AM
CaBaRet's Avatar
How old is your battery and have you checked the stator with multimeter
Old 07-12-2018, 01:44 PM
WendellB's Avatar
Default Mosfet
New battery and fully charged. Checked the stator there was 0.4 ohms restance between each pair of contacts and each contact was not grounded out, an open condition.
Old 07-12-2018, 02:40 PM
CaBaRet's Avatar
Have you checked for AC voltage from the stator?
Old 07-12-2018, 06:33 PM
WendellB's Avatar
No can you tell me how to do that?
Old 07-13-2018, 12:21 AM
CaBaRet's Avatar
Yes, small right up here that will explain it, you need to set your multimeter to at least 100vac and test the wires coming from the stator, go to last page
File Type: pdf
Old 07-13-2018, 05:43 AM
74demon's Avatar
Have you tested the voltage with a load on it?
Turn on the high beams and hold the brake while at 5k rpms and see if the output increases.
Ryanrad2008
08-21-2017 03:00 PM
eidura
06-04-2017 11:20 AM
chrstphrmrrs
03-13-2016 05:58 PM
cloudee1
09-26-2013 12:40 AM
95ninehundredRR
01-06-2007 09:11 AM
Quick Reply: Mosfet REG/REC charging
