Mosfet REG/REC charging
So I just installed a mosfet rectifier/regulator on my Honda CBR 600 4fi but have some concerns. When running my bike at 5000 rpms the voltage output does not go above 13.3 volts. I was expecting 14.0 volts and wonder if I can trust this unit to keep me going. Does the Mosfet not produce as high voltage when the battery is fully charged? Seems it should. I check the stator and it is not open on any of the three posts and neither is there a short to ground anywhere. The plugs seem to be in all the way as they clip together. Voltage of the battery is 12.6 and there is some output at 13.3 volts is this just an anomaly of the Mosfet? Thanks for your time.
