06 cbr f4i charging issue
Old 03-11-2016, 08:11 PM
chrstphrmrrs's Avatar
Angry 06 cbr f4i charging issue
Alright guys is anybody knowledgeable in electrical charging systems.
Here's my process that I did:
Put a new stator in.
Checked the DC voltage at the battery terminals with voltmeter and bike on. Volts read 12.3
Unplugged regulator from wiring harness, and unplugged stator from regulator.
Turned bike on, tested DC volts from stator plug and couldn't figure out which port to do positive negative.
Got mad, left garage bike still not charging
Old 03-11-2016, 10:19 PM
Conrice's Avatar
Stator doesn't put out DC.... It puts out AC, hence the R/R, that converts it to DC, to charge the battery. YouTube how to check a stator. They're all pretty much the same, whether its a Harley or a Honda.
Old 03-12-2016, 12:21 AM
74demon's Avatar
Check ohms at the stator. open to ground, circuit to each other.
You do know to check the charging output at the battery at 5k rpms, right? They don't charge much, if any, at idle.
Old 03-13-2016, 12:36 PM
At 5k rpms it's charging at 18- 19 volts, is that to much?
Old 03-13-2016, 05:57 PM
74demon's Avatar
Originally Posted by chrstphrmrrs
At 5k rpms it's charging at 18-19 volts is that to much
Way too much. Your regulator is shot.
Don't ride it until its been replaced or you will fry things.....
Old 03-13-2016, 05:58 PM
omg209's Avatar
yes it is too much. should be around 14.7v cant figure out how to post the fault finding diagram but its here somewhere on the forum
hmm
01-30-2015 08:39 AM
markybwoi
04-11-2011 11:35 AM
marc0011
09-24-2007 10:28 AM
marc0011
09-27-2006 07:18 AM
maxima/nismo
08-18-2005 05:41 PM
Quick Reply: 06 cbr f4i charging issue
