a little oil around the engine?
Old Jan 3, 2009 | 08:38 PM
LiMe_GrEeN_MaChInE's Avatar
Default a little oil around the engine?
anybody else have a couple spots of oil on there engine, my bike is pretty much totally tore down and i have been sprayin either on the engine to get it cleaned up, i dont think its ever really been "cleaned"
Old Jan 3, 2009 | 08:51 PM
Incognito's Avatar
Official CBRF Welcome Crew Undercover Agent
Default RE: a little oil around the engine?
Nope ~ mine is nice & clean. First thing I did when I gotit homewas give it a bubble bath.
Old Jan 3, 2009 | 09:26 PM
eljrc16's Avatar
Incog what did you clean the engine with? Was it degreaser or what.
Old Jan 4, 2009 | 12:04 AM
Incognito's Avatar
For the heavy stuff (tar, oil, ect.) use a heavy duty degreaser like pictured below. But only for the real dirty parts like the headers,oil cooler,and oil pan. For the rest of the bike, dishwashing liquid is an excellent "mild" degreaser that won't harm plastics or rubber wiring.Bristled brushes are the way to go with engines (toothbrushes). Rinse everything off with water.Always keep liquids away from electronic devices (ecu, rectifier, lights) and their connections. For those, a damp towel works best. I like to make sure and allow plenty of time to allow the engine to dry off before operating. That being said, the Engine Brite smokes like a mother for the first 5 min. when you start the engine, but it eventually stops & evaporates.
warning ~ never attempt to spray a hot engine with water. I have an aunt who's car was overheating. She thought it would be a good idea to throw a bucket of water on it. Ended up cracking the engine block. Doh!
Old Jan 4, 2009 | 11:31 PM
so it is pretty normal around the oil pan? thanks for the input guys, im still pretty young and this is my frist "street bike" thanks again
Old Jan 5, 2009 | 01:19 AM
thirdgenlxi's Avatar
Ironmang
My motor is bone dry except for one little spot. Ever since I installed the APE manual CCT, over time a tiny tiny bit of oil seeps out from around it (even with the gasket). It's not even close to enough to make the oil level go down, it's just enough to make dirt and crap stick to it. Never actually leaks down to the ground or anything, just right around the CCT and on the edge/corner of the valve cover. Everything else... bone dry (although sometimes dirty)
If you use some brake parts cleaner after every oil change to clean off around the oil filter and the drain bolt, that helps keep everything clean too. Over time those little amounts of oil left behind after an oil change will run down into other places and it'll start looking like a leak
Old Jan 5, 2009 | 12:12 PM
thrasher572's Avatar
One of the best degreasers is tide high effeciency laundry soap..try it you will be amazed.
Old Jan 5, 2009 | 01:50 PM
Incognito's Avatar
Sounds better than dish-washing detergent ~I'llgive it a try.
Old Jan 5, 2009 | 06:41 PM
my oil level never goes down, like i said this has been built up for looks like 6 years ha ha, she is shining now!
lanceam24
F2 Tech
Feb 21, 2011 11:45 AM
knifemaker87
F2 Tech
Sep 17, 2010 09:21 AM
julius1
CBR Zone
Jan 4, 2010 11:32 PM
98formulaLS1
Aug 24, 2009 10:04 AM
Workwell
Jan 14, 2009 10:02 PM
