Installing Micron Exaust
Okay so I'm a little confused here trying to install this exaust. I have everything off and when I go to install it, I have no idea where this "race springs" that they gave me go. These instructions are made for like a bike know it all and I'm not the smartest person here so any help would be nice
P.S. This no picture install thing sucks a big one.
EDIT: The thing I'm having trouble with is where to put this bolt and washer they gave me and wtf to do with these springs. Everything else is easy :P
The springs go on the midpipe & the muffler
Slide the muffler onto the midpipe & then hook one end in the hook on the midpipe and stretch the other side of the spring to the hook on the muffler
The bolt and washer are for the strap that goes around the muffler & you use them to go through the hole on the passenger footpeg/exhaust bracket and use the stock nut (that goes on the back--the bolt they gave you will thread into it). Thewasher should goinbetween the front of the strap & the bolt
Just like Snob says: Slide the muffler onto the midpipe & then hook one end in the hook on the midpipe and stretch the other side of the spring to the hook on the muffler
This is my right side with the fairing on...so you have to use some imagination. Underneath where the "x" is, there will be a tab on the midpipe...the spring will be stretchedto the circled nut. I believe there is a metal tab that came with the hardware for the pipethat will go underneath this boltand will have an attach point for the other side of the spring:
Hope this helps and isn't more confusing...post up when you are done.
ORIGINAL: voodoochyl
