Installed Led Blinkers, now Fast Flashing...
Old Sep 15, 2005 | 02:47 PM
BoostinFD's Avatar
Default Installed Led Blinkers, now Fast Flashing...
The rear blinkers that I installed are Led ones. Well as soon as i hooked them up they started flashing like only one of them works. Is there a resistor i should put in between or something like that to make it flash normal?
Thanks
Old Sep 15, 2005 | 06:06 PM
regener8ed's Avatar
Default RE: Installed Led Blinkers, now Fast Flashing...
yes, LED's have a much lower resistance than filament bulbs which pulls more current and can screw with flasher relays. you will need a set of load resistors to bring the system back into tolerances.
Old Sep 15, 2005 | 06:59 PM
chainstretcher's Avatar
Admin Emeritus & MVN
You'll need 2 of the ceramic type resistors -- I think they're 5 ohm / 100 watt. Wire each in parallel and it'll make the blinkers normal again. I eventually took my resistors back out -- I like the fast blinking. Cagers appear to see fast blinky things. And sometimes shiny stuff. Ohhhhh pretty shiny stuff. I hate cagers.
Old Sep 15, 2005 | 09:40 PM
formulafire99's Avatar
left mine blinking fast too,people seem to pay more attn. to it.
Old Sep 16, 2005 | 12:23 AM
BoostinFD's Avatar
Yeah i found how to do it. It's actually 8ohm 20watt resistors and you wire them in parallel.
Thanks a lot guys.
Old Sep 20, 2005 | 02:16 PM
600Grr's Avatar
Check out this online tutorial for rear taillight conversion...
http://www.biperformance.ca/tutorial.htm
It calls for two of these:
5 ohm Power Resistor, 10W Power Rating ( working in momentary overload )
Digikey.com part number: 810F5R0-ND
pugsly1002000
Jul 13, 2011 04:14 AM
jnicola
Jan 18, 2010 05:36 PM
tb
Mar 13, 2007 10:59 PM
Pyle
May 17, 2006 10:37 PM
al
Oct 5, 2005 07:02 PM
