fast flashing
Old Mar 11, 2007 | 08:31 AM
tb's Avatar
tb
Default fast flashing
right ive just put some new indicators on my bike front and back and now there flashing there **** off,with this i mean there flashing a lot faster than they ever was,its like when you have blown a bulb but there both working anyone no the reason for this,any help please[/align]
Old Mar 11, 2007 | 03:07 PM
KidCr3nshaw's Avatar
Default RE: fast flashing
Are you sure they were wired correctly? Both the front and rearare 3-wire, and the majority (that I've seen), of aftermarket signals are 2-wire. The three wire allows them to be markers as well as turn signals (meaning they'll be on when you're not using them and flash when you are).
You may have shorted your turn signal relay if you wired them wrong. Double check. If you need a manual with the wiring diagram, lemme know.
Old Mar 11, 2007 | 09:37 PM
BigT_2008's Avatar
anytime you use a bulb that uses less power than stock, such as an led, they will blink a hell of alot faster. Probably just need to add a resistor to the positive led of the light. Mine blink like crazy but i like it because people seem to take notice better.
Old Mar 11, 2007 | 10:12 PM
richterat83's Avatar
Are your new indicators LED? If they are, and, you really can't live with the fast blinking, you'll need to install a resister somewhere on the line, but, if I recall correctly, use cation, as to I've heard that they get hot.
I upgraded my taillight and signals to an integrated tail from ClearAlternatives, and, the signals blink alot faster than before, but, as stated, it gets alot more attention.
Tylor
Old Mar 12, 2007 | 12:34 AM
kwong2001's Avatar
http://cgi.ebay.com/ebaymotors/honda...spagenameZWDVW
That should fix the problem
Old Mar 13, 2007 | 10:59 PM
MKuz14's Avatar
You may want to check your ground too. If its not grounded, that will let them blink faster. But what the other guys said sounds righ too, they know from experience
letsride
May 27, 2013 04:57 PM
pugsly1002000
Jul 13, 2011 04:14 AM
Hindra
Mar 21, 2007 09:38 PM
recker
Apr 3, 2006 07:39 PM
BoostinFD
Sep 20, 2005 02:16 PM
