Inconsistency with Brake Pad Wear
Old 05-21-2010, 11:07 AM
IIRyan's Avatar
Default Inconsistency with Brake Pad Wear
Just a quick question out of curiosity:
I took off my front right brake rotor to inspect the condition of the brake pads and I noticed that the one on the outside of the disc looked almost brand new while the one on the inner side of the disc was approximately half way worn. Is there a possibility that my brake rotor is somehow misaligned causing the one pad to wear faster or could it just be that the previous owner replaced one pad and neglected the other?
Thanks.
Old 05-21-2010, 11:28 AM
Krux's Avatar
Any shakes up front? I just replaced mine and one side had it worn all the way to metal yet this was caused by vibration from the rotor eating the pad away.
If the piston's aren't moving freely either this will cause a issue as well. Since one side will get applied pressure vs the other side.
Old 05-21-2010, 01:53 PM
IIRyan's Avatar
No shakes at all. How would I check or repair the pistons?
Osolage
08-28-2013 11:13 AM
Michaud85
06-22-2012 11:22 AM
specializedfuji
TRG Coating
07-06-2008 09:29 PM
cb2cbr
07-02-2008 10:50 PM
f44life
06-12-2008 09:58 PM
Quick Reply: Inconsistency with Brake Pad Wear
