Brake Wear
Old Aug 14, 2013 | 10:40 PM
Osolage's Avatar
Default Brake Wear
Hi all.
My birthday is coming up and it's looking like I'm gonna need to blow some money on general tech for my bike. I've put nearly 4K miles on it since I bought it back in Jan. It has about 14K miles on it at this point. Thinking I'm gonna need to replace the brakes and tires before going into the fall season.
:-D
My question is, "How should I know whether I need to replace the brake pads or the discs?" Like what indicators should I use?
Thanks a bunch for your help!!!
Old Aug 15, 2013 | 03:49 AM
wheelnut's Avatar
Welcome Crew
your disc will have a minimum thickness stamped on it, just measure it with a set of verniers,your pads you can do by eye but dont let them get to low or your risk scoring the disc. check for even wearing over the whole pad area, some pads have a grove in the middle and when the pads are level with this its time to change them
Old Aug 15, 2013 | 08:17 AM
DonnyBrago's Avatar
Originally Posted by Osolage
Hi all.
:-D
Discs will not be anywhere near worn after only 14k miles. Min thickness is 3.5 mm but most people manage to warp them from poorly maintained brake calipers before getting anywhere near that.
Brake pads become thinner as they wear. I tend to replace at about 1.5 mm, or if there is a groove carved into the pad, when the groove is no longer visible. Changing pads is an easy job.
14k miles is approaching the 16k major service, this includes a number of things, most notably the valve check/adjustment. This is a relatively difficult/time consuming job and can become expensive if adjustment is required.
Old Aug 25, 2013 | 08:14 PM
Osolage's Avatar
Talking Thanks wheelnut
Thanks for the tips, wheelnut!
Old Aug 25, 2013 | 08:16 PM
Osolage's Avatar
Thanks, DonnyBrago!
Sounds like I need to attend to the pads very soon. Do you know if them being too thin will cause vibration when stopping? Sometimes I could swear that I feel a little jiggle when coming to a hard stop.
I'll have to save up for that 16K service. Sounds like it's better to get the shop to do that for me as I'm not that much of a mech, yet.
Old Aug 28, 2013 | 11:13 AM
DonnyBrago's Avatar
Thin pads wouldn't give you a vibration during braking.
A warped disc will (and is the most common cause for bike brakes), but so will a build up of pad material on the disc or corrosion behind the disc mounting bolts.
If you have managed to warp a disc in 14k then a binding caliper is most likely the cause - give both brake calipers a clean out when you fit the new pads. If it is not a severe vibration then you can ignore it for now but it will get worse with time.
Michaud85
Jun 22, 2012 11:22 AM
IIRyan
May 21, 2010 01:53 PM
specializedfuji
TRG Coating
Jul 6, 2008 09:29 PM
cb2cbr
Jul 2, 2008 10:50 PM
f44life
Jun 12, 2008 09:58 PM
