idling problem
Old Mar 31, 2012 | 03:46 PM
donnygeewebb's Avatar
Default idling problem
Hey guys. Well I tried adjusting my idle with the cord above the engine case and it wont idle down. Its screaming when its sitting and its obviously a problem. Any suggestions??
Old Apr 1, 2012 | 04:08 AM
96shox's Avatar
idle when cold goes up to 3k rpm.. Is it fully warmed up and still above ~1600rpm? If so try the adjuster and if its not doing anything it might have fallen out of place.
Do these bikes have a IACV?
Old Apr 1, 2012 | 11:37 PM
I believe they do. And the adjust hasn't come loose because I can trace it back up the connection. I can turn it up but once it gets to a certain low, it wont go any lower, and it still remains too high. The only thing I notice is that the rpm's increase when the bike becomes hotter, and currently the fan isnt coming on. Could that be the problem? or d oyou think those two are associated.
Old Apr 1, 2012 | 11:45 PM
74demon's Avatar
Just a long shot...check your coolant level. It needs to see coolant in the wax unit to pull the idle down.
Old Apr 2, 2012 | 07:42 AM
HellrazerinDC's Avatar
After I had dumped my bike, I noticed my bike was idling higher as well, and I figured it was because coolant spilled out. Once I put more back in there, the idling issue was resolved.
Old Apr 2, 2012 | 10:51 PM
Alright, Ill try to fill it up a good ways tomorrow. I just recently exchanged the old fluid for some new coolant, so this might be a long shot, no doubt. But its worth trying the cheap stuff first. Ill let yall know.
Old Apr 3, 2012 | 09:27 PM
Hey guys that did the trick! I just had the coolant level to low lol. Now on to my speedometer and radiator fan problem lol
Old Apr 3, 2012 | 10:34 PM
74demon's Avatar
Very cool....something simple
Old Apr 4, 2012 | 10:56 PM
Yes! Thanks you all!
kowen1208
Aug 27, 2012 09:27 AM
projectboost
Jun 16, 2011 12:54 AM
Dfbewley2
Mar 30, 2011 11:38 AM
six00RR
Nov 2, 2008 08:56 PM
Danie
Dec 4, 2006 06:01 PM
