Idling Problem
Old Oct 29, 2008 | 06:05 PM
six00RR's Avatar
Default Idling Problem
on my 06 600rr i went out to start it up and i havent started it for a few days cuz its been kinda chilly..and when i started it it was idling real high like around 3-4rpms..not like it does normally..so i gave it some gas and it reved up really high and took for a sec to calm back down..so i tried to adjust the idller and didnt notice a differnce in either direction..so i rode it for a sec and it was riding normally..but when i come to a stop it barellys stays on..and cuts off somtimes..so i think i adjused the idle to far down..but i tried to re adjust it and it doesnt do ne thing..i can tell that it came unpluged or somthing..does anyone have any suggestions on how to fix it? thanks
Old Oct 29, 2008 | 06:50 PM
tomp's Avatar
Default RE: Idling Problem
When you first turn it on it should idle high for 10-20sec. Your idle should be set around 1100-1300rpm. Reving it up "really high" is not good, nor do you need to rev it to make it idle it will go to idle on its own.What came unpluged?
Old Oct 29, 2008 | 07:56 PM
justasquid's Avatar
it will idle high at intial startup like already said until it warms up. When the bike is warming up, the fast idle or (enrichener) curcuit takes over so your idle adjust wouldnt have any effect on it until it warms up.
As far as the idle adjuster coming unplugged, I'm not sure. I dont know if you turn it too far one if it will snap off or not, but that may be what happened.
thats the one thing you will learn is dont make any adjustments on anything until the bike is at operating temperature.
Old Oct 29, 2008 | 11:00 PM
six00RR's Avatar
yea i think i might have turned it to far..cuz once the bike got to normaly temp it was idling extremly low..it barely wants to stay on
and when i first started it i didnt rev it hard..i ment that when i reved it..and let of the gas the rpms kinda went up a little and slow rent down..kinda like i was still givin it gas...but i think i might have un twisted it cuz usually when i start it up it idles normally and the other day it was idling like crazy so i didnt let it warm up and just went to adjustin the idle..but i dint notice a difference..until it was warmed up..so i ****ed up lol...but im pretty sure i untwisted it cuz it doesnt feel tight
and by the way tomp..thas exactly what my cbr looks like mad props lol
Old Oct 30, 2008 | 01:27 AM
tomp's Avatar
ORIGINAL: six00RR
05-06 are the best looking 600RR's
Old Nov 1, 2008 | 11:25 AM
six00RR's Avatar
[sm=icon_ladiesman.gif]hahah
so does anyone know how to fix the idler?? id rather do it myself then take it to a shop..money is tight lol
Old Nov 1, 2008 | 05:09 PM
tomp's Avatar
You'll probably need to remove the tank cover and pull the tank back, to get good access.Thethrottle stop screwshould screw back into it.
Old Nov 2, 2008 | 07:44 PM
six00RR's Avatar
hmm..ok i know this might sounds stupid but when i left the tank up..do i need to drain the gas first? and other than removing the tank is this a fairly easy thing to fix?
Old Nov 2, 2008 | 08:44 PM
justasquid's Avatar
You dont have to remove the fuel from the tank. I think your bike has an internal fuel pump, so when you disconnect the fuel line, you will have a little bit of fuel come out, but it will only be the amount that is in the line. The fuel pump prevents fuel from comming out. If there is an external pump, there will be a shut off valve once you lift the tank. Unbolt the tank, the front and rear bolts.. then lift the front of the tank and allow the rear part of the tank to rest on the bike. there is a small cradle there so you can have the tank elevated while you disconnect the lines.
You may not have to disconnect the lines though. Just lifting it up may be enough to gain the access you need.
If you unscrewed the idle adjuster. you may only have to put slight pressure on it and turn it clockwise. If it is indeed broken, you will probably have to replace it.
Old Nov 2, 2008 | 08:56 PM
six00RR's Avatar
sounds easy enough..and impretty sure i just unscrewed it..i hope i dint brake it..but ima start working on it tom and see wat happens lol
kowen1208
Aug 27, 2012 09:27 AM
donnygeewebb
Apr 4, 2012 10:56 PM
projectboost
Jun 16, 2011 12:54 AM
Dfbewley2
Mar 30, 2011 11:38 AM
Danie
Dec 4, 2006 06:01 PM
