600 fs2 idling problem
Old Nov 26, 2006 | 04:08 PM
Danie's Avatar
Default 600 fs2 idling problem
I have just done a minor service- plugs, filters, oil on my FS2.
On the startup it was reving high 4000rpm. I wasn't too concerned for it was cold, but when it reached 50 degrees and still kept on reving high i knew there was a problem.
I removed the air box again to see if I could spot a problem. Not to my untrained eye.
Does anybody have an idea what could have happened and why it keeps reving at 4000rpm.
Please advise,
Thanks
Old Nov 27, 2006 | 10:45 PM
walkerg00's Avatar
Default RE: 600 fs2 idling problem
Have you checked the idle adjuster screw located right behind the fuel switch? Did this just start after you did the maintenance? Seems odd that the work you did would have caused the symptoms you described.
Old Nov 28, 2006 | 02:09 AM
ThisisMickey's Avatar
its reving without the choke? I had some problems with my throttle cable, but my rpms went down. i would say check either the throttle or the choke cable.
Old Dec 4, 2006 | 06:01 PM
Danie's Avatar
Thanks for the replies, found the problem. It was a faulty thermostat in the radiator. No biggy.
Cheers anyway,
Danie
kowen1208
Aug 27, 2012 09:27 AM
donnygeewebb
Apr 4, 2012 10:56 PM
projectboost
Jun 16, 2011 12:54 AM
Dfbewley2
Mar 30, 2011 11:38 AM
six00RR
Nov 2, 2008 08:56 PM
