Mechanical Safety of Wheelying?
Old Dec 1, 2006 | 05:30 PM
BlueWheelies's Avatar
Default Mechanical Safety of Wheelying?
So I parked my 93 900RR after a short ride home from class, on which I did one soaring wheelie(closest I've ever been to balance point I think), and a lower but sustained wheelie at about nine'o'clock or so. I happened to notice a pink puddle dripping from around the headers. I looked through the vent in the fairing, and it looked like it was coming from one of the hoses, and not the radiator itself.
Is it dangerous to anything mechanical other than forks, fork seals, or rims to do high wheelies with hard landings?
Thanks
Old Dec 1, 2006 | 05:36 PM
Tahoe SC's Avatar
Default RE: Mechanical Safety of Wheelying?
you use high octane? sounds like it was gas coming out of the hose.
as far as mechanical safety...i know prolonged wheelies and lots of them does eventually wear out the engine and sometimes prevents oil from getting into the cyclinder(s).
Old Dec 1, 2006 | 06:17 PM
Err's Avatar
Err
add a quart of oil and you'll be ok for long wheelies. i'm running 5 in my 900 and haven't had any problems.
suduki's are known for blowing engines when doing long wheelies, if they don't have an oil pickup.
Old Dec 2, 2006 | 12:53 AM
racer212's Avatar
Long/high wheelies can cause oil starvation, and on 900's sometime overflow oil out of the crank breather. Some of the guys that used to do 900 conversions to F2's/F3's would route a small catch bottle under the seat then back the the oil fill on the right.
Old Dec 2, 2006 | 04:15 AM
JBaz's Avatar
Overflow drain most likely. When you do wheelies and you have a full or semi-full gas tank, gas will go in the gas overflow drain and exit out of the bike. Bikes weren't designed to do wheelies but they can do it.
Old Dec 5, 2006 | 12:38 PM
hondadriver4life's Avatar
ORIGINAL: JBaz
yeah, lik eany superbike manufacturer doesnt think that we use their beautiful machine for lol
but on the subject it does sound like oil. just check your oil view window and see if youre low. if you are overfill it if you intend to do more wheelies.
mjp94cbr100f
Jan 1, 2013 12:42 PM
CBRnewbie
Feb 14, 2011 12:59 AM
Procrastinator
Jun 10, 2010 08:55 PM
Jay1623
Jun 15, 2009 05:08 PM
cbrtuner1
May 15, 2007 07:19 PM
