idling problem
Hey guys. Well I tried adjusting my idle with the cord above the engine case and it wont idle down. Its screaming when its sitting and its obviously a problem. Any suggestions??
idle when cold goes up to 3k rpm.. Is it fully warmed up and still above ~1600rpm? If so try the adjuster and if its not doing anything it might have fallen out of place.
Do these bikes have a IACV? |
I believe they do. And the adjust hasn't come loose because I can trace it back up the connection. I can turn it up but once it gets to a certain low, it wont go any lower, and it still remains too high. The only thing I notice is that the rpm's increase when the bike becomes hotter, and currently the fan isnt coming on. Could that be the problem? or d oyou think those two are associated.
Just a long shot...check your coolant level. It needs to see coolant in the wax unit to pull the idle down.
Originally Posted by 74demon
(Post 1145889)
Alright, Ill try to fill it up a good ways tomorrow. I just recently exchanged the old fluid for some new coolant, so this might be a long shot, no doubt. But its worth trying the cheap stuff first. Ill let yall know.
Hey guys that did the trick! I just had the coolant level to low lol. Now on to my speedometer and radiator fan problem lol
Very cool....something simple
Yes! Thanks you all!
