At Home Powder Coating A Sucess
Great post, thanks! For those that have access to a sand/bead blaster, a light spray using glass beads does wonders for the surface preparation. It will give you a uniform satin texture, even in the areas that are hard to reach. As zimdbw74 says, the prep work determines the quality of the final product.
This is amazing, great work! Just curious for those of us without air tools, what method of spraying did you use (compressed air)? Does the kit require an air compressor or are there canisters that can be attached? 25psi is nothing, I know HF has those small pancake air compressors for dirt cheap.
If you didn't want the added expense of an air compressor the Craftsman Kit is a self contained system that does not require and air compressor. The quality of the craftsman gun is from what Ive read not the greatest but you the end result is the same. You Can pick one up on ebay for about $35
When I've done powdercoating, we used an old electric range. Put the metal grate in the highest groove and use it to suspend the parts. I figured laying them on something would cause the coat to have bare spots
After using a blast cabinet on a few parts, I found it was easier to just use aircraft stripper to remove paint/coating from most parts. Especially on the clutch cover that has a bearing pressed inside it, won't get sand in there.
I wish I'd never gotten rid of that bike
Yeah I keep searching craigslist for an old electric range so I can do larger parts like the stator cover and clutch cover. I have some friends at work that want to try and do rims and other large parts from their projects. I don't have access to a blast cabinet so I did use aircraft stripper on my rear sets because I had previously painted them and it worked great.
Your parts look top notch. Good job
Thanks,
I wish I'd done my lower fork tubes. That greenish brown honda put on those and the stator and clutch cover did nothing for the bike.
Not sure about everyone else, but I use eastwood powder and was always very pleased with it. Their high gloss black matches the black paint on the lower side fairings nicely.
