high mount and passenger footpegs
Old Sep 15, 2005 | 07:38 PM
maxiav's Avatar
Default high mount and passenger footpegs
Ok, new in the forums. Did my searches and it says you can't keep your passenger pegs with a high mount. I have a Two Bros. exhaust. Anybody done any custom extensions or anything?...
Old Sep 15, 2005 | 09:43 PM
formulafire99's Avatar
Default RE: high mount and passenger footpegs
some high mounts do allow you to keep your passenger pegs.I am not too sure wich ones though.
Old Sep 16, 2005 | 02:55 PM
maxiav's Avatar
anybody else? can I get any adapters? Am I the only one using a Two Bros exhaust ?
Old Sep 16, 2005 | 06:37 PM
Turboedsupe's Avatar
My M4 high mount allows me to use the passenger pegs. They have little extensions that make em stick out more and clear the exhaust
Old Sep 16, 2005 | 08:28 PM
Tahoe SC's Avatar
you can do this with just about all high mounts...almost but not all...
go to a hardware store and look for some sleeves/collars/washers, basically they are hollowed out tubes of steel, etc. find out how long you need these to be and then buy the corresponding bolt. make sure the sleeves are fairly thick because there will be more stress to that area when someone sits back there as the pass. peg is not extended way out there.
Old Sep 19, 2005 | 11:34 PM
traitorhound's Avatar
the scorpion high mount lets you keep the pegs. . .the sleeve are a little too long for my taste. . but ill get arolund to gettign new shorter ones whenever i get around to it
Old Sep 20, 2005 | 12:46 PM
Tahoe SC's Avatar
why not just cut those *****?
when it's too long i get sketchy since there's so much more stress added to the connection point.
Old Sep 20, 2005 | 10:45 PM
yea i would cut them too. . .but right now i don't have the facilities that would allow me to do it the correct way (ie straight) so it'll stay like that till i can go back to my garage with tools
Alex Poland
Nov 30, 2012 02:36 PM
luckyme77
Jul 24, 2010 02:25 AM
nor_cal_cbr
Apr 13, 2009 08:36 PM
Nobble
Jun 15, 2007 03:04 PM
uknoejuno51hoe
Feb 2, 2007 02:00 PM
