Help!!! I need to understand what is going on with this bike!!!
Old May 29, 2009 | 05:38 PM
PlayfulGod's Avatar
Originally Posted by musantemike
how do u check the "other end" of the ground wire.
it should be bolted to the frame or engine. And yea its a pita to get too lol.
Old May 29, 2009 | 07:08 PM
bwayers's Avatar
you need an ohm meter, then touch either lead to the negative terminal of your battery and the other to a ground on the frame
this will tell you if there is continuity between the ground side of the battery and where it is grounded to the frame
DragonCBR
Jul 13, 2008 10:39 PM
deerslayer
Mar 28, 2008 12:50 PM
NicIsSlick
Jun 23, 2007 08:58 PM
f4iguy8804
Jun 22, 2007 07:19 PM
sk8r20
Aug 11, 2006 05:39 PM
