Help with f4i no start
Hi all-
Having troubles with my 02 F4i, hoping someone here could give me some advice. Back story is that the bike sat for more than a year; when I tried to start it, it sputtered and died. Then it wouldn't even sputter - just crank to no effect.
The plugs look OK and it has spark, so I tried doing fuel diagnosis. In the process of doing the fuel flow test detailed in the service manual (jumping the fuel cut-off relay) I must have damaged something, as now the fuel pump will run manually but won't prime. So my question is - what could be keeping the pump from priming when you turn on the kill switch?
JayBoCC2
06-23-2009 10:23 PM
