height adjustment
Old Mar 18, 2012 | 01:23 PM
martinjr96's Avatar
Default height adjustment
Does anybody know of you can adjust the highth on a 02 f4i?? I.want to raise it up a little higher....
Old Mar 18, 2012 | 06:25 PM
boredandstroked's Avatar
Front? No. Rear? Yes its easy. You put some steel washers in between the frame and top shock mount. The stud goes through a cross bar and a nut secures it. I've heard the earlier F4i's had a short stud for the shock mount and require the later mount with a longer stud.
Old Mar 19, 2012 | 12:43 PM
martinjr96's Avatar
Sweet, thanx!!
Old Mar 19, 2012 | 07:21 PM
madman's Avatar
You can also cut the bolt off the OEM mount, drill a hole in it, and use a longer bolt if yours is too short.
I ran a single spacer for a while and you can cut a notch in it so you only have to make a little space for it and slide it in. I wonder though if there is a possibility of the shock spinning if you put several washers in. Might wanna weld them to the mount if so.
You can also add a little bit of height by running a 190/55 instead of a 180.
Curious as to why you want to raise the front and rear?
Old Mar 19, 2012 | 10:58 PM
He could want to raise the bike to get more cornering clearence. I don't suggest using a 190 rear tire unless its a dunlop race slick that is designed for a 5.5" wide rear rear. Street 190's are designed for 6" rear rims. I have 3-4 washers between my shock mount and frame and have about 18,000 miles on it that way with no shock movement yet.
Old Mar 20, 2012 | 10:26 AM
martinjr96's Avatar
Yea i want to raise the rear a lil higher for cornering specially when i have a passanger, i have a 190 and have no problems
woodypk
Jan 16, 2011 06:32 PM
1iwilly
Aug 11, 2009 10:30 PM
rattfink188
Nov 9, 2007 01:07 AM
unhallowed
Nov 17, 2005 02:50 PM
brcson
Nov 11, 2005 03:43 PM
