HEALIGHT!!!! quick help
Old Mar 19, 2012 | 09:34 PM
camaroloverx4's Avatar
Default HEALIGHT!!!! quick help
hey guys the past few nights i have had my headlight cut out on me while im riding down the road and ill pull over have to turn the bike on and off a few times to get it to stay on
any ideas???
Old Mar 19, 2012 | 09:39 PM
madman's Avatar
relay and or loose/broken wiring?
Old Mar 19, 2012 | 10:04 PM
Aleksander's Avatar
When my battery was dying my bike was doing the same thing, i typically have both lights on all the time wired to the stock high beam switch so either on or off for both. When my battery was getting low it would usually shut off one of the beams, and if it got really bad it would shut off both. This was mostly because my R/R was shot and was toasting the battery and fried a lot of stuff.
Old Mar 20, 2012 | 09:53 AM
I got the battery just last summer so I wouldnt think it'd be bad but I'll check it out
The turn signals and everything else stay on and everything it's just the lights
Old Mar 20, 2012 | 12:08 PM
Sick97SS's Avatar
Common issue with the solder joints coming lose in the starter button box.
Open up the starter switch (two screws from the bottom) and you'll see 4 small dabs of solder in there with wires. Guaranteed one of them popped off.
A fine tip soldering pen with a steady hand will fix this right up. Fixed mine 2 years ago and it's been fine ever since.
oxyg3ne
F4i - Wanted
Oct 13, 2010 06:35 PM
z400motocross
Sep 30, 2010 03:44 PM
twist
May 23, 2009 12:24 PM
redbbwoy
Dec 20, 2007 05:13 PM
PierPressure
Feb 28, 2006 11:48 PM
