Head lights?
Old 12-13-2010, 06:57 PM
Jeff0044's Avatar
Default Head lights?
Okay I noticed that my CBR has 1 headlight and the other one looks like its burnt out.. when I turn the high beams on they're both on my friend told me that one light (left side) is the low beam and then the high beam is on the right side.. is this true or do I need to replace the light? its a 2003
Old 12-13-2010, 08:00 PM
LasVegasHarley's Avatar
it's true! but there is mod on this forum to make them both turn on when using low beam.
Old 12-13-2010, 08:21 PM
Xander F4i's Avatar
Or you can just leave your brights on...at least in the daytime...
Old 12-13-2010, 09:17 PM
Jeff0044's Avatar
very true.. but hmm.. ok if I made them both turn on while on low beams would it be like I had the high beams on or would it be dim like the other one and would I be able to still use the high beams?
Old 12-13-2010, 09:40 PM
Krux's Avatar
Just leave it. That's how they wanted it from factory then I wouldn't touch it.
Old 12-13-2010, 09:43 PM
Jeff0044's Avatar
They also wanted it stock or they would ave put power commanders and stuff on em :P but ya I prob will leave them that way and anyways are power commander 3s are to install do u have to do anything like programming it in?
Old 12-13-2010, 10:13 PM
jp_greenville13's Avatar
hahaha. Newb :P Yeah that's normal all hondas with duel headlights are like that. As for the PCIII's you have to download a map (program) to the unit then I'm pretty sure it just piggy backs to the ECU. Not positive on that though. I did see one on ebay the other day for fifty bucks buyitnow if you're looking....
Old 12-13-2010, 10:49 PM
vangill's Avatar
July 2010 ROTM
power commanders really dont make the f4i faster........... they make it run better after u mess up its stock map with a new slip on or filter
and the high beam can NEVER be a low beam, its angled different, youll have to angle it down, u might as well just leave it on all the time if u want both lights.
Old 12-14-2010, 12:18 AM
600F4inoober's Avatar
The stock map is fine and ideal for stock components or even just a slip on...I have a VERY unrestricted pipe with the stock tune and it runs great/ very smooth...when you add an aftermarket air filter (B&M/K&N) in addition to the slip on, you may want to get a new tune/map/pc3. The additional flow of air in (a slip on makes next to no difference on air out but hey!) calls for a new mapping of the a/f ratio. SO more than anything the new tune/pc3 tells your bike "hey theres more air flowing in and out" so lets advance timing and remap the fuel.
Anyway, regarding the headlights...the actual reflective housings in the low and high beam lens are different. The bulbs are the same. So to run that "mod" someone stated earlier would merely have you running your low and high beam together as default settings which makes no sense to me...to actually have both bulbs at "low beam" you would have to tear out the housing and reinstall another low beam housing in the high beam lens and then angle it appropriately (which I dont know why anyone would ever go through that much labor to do this?)
They make some new "ultra bright" H7 bulbs that you could stick in there or do what most do..get a DDM HID kit
Old 12-14-2010, 02:31 AM
Zero1080's Avatar
^Good stuff.
horse_power777
03-22-2011 09:03 AM
ny00jp
12-27-2008 11:39 PM
radical rich
09-19-2007 02:45 PM
ducati650
06-19-2007 01:05 PM
CBR Blue
09-14-2006 05:12 PM
Quick Reply: Head lights?
