Head lights?
Okay I noticed that my CBR has 1 headlight and the other one looks like its burnt out.. when I turn the high beams on they're both on my friend told me that one light (left side) is the low beam and then the high beam is on the right side.. is this true or do I need to replace the light? its a 2003
it's true! but there is mod on this forum to make them both turn on when using low beam.
Or you can just leave your brights on...at least in the daytime...
very true.. but hmm.. ok if I made them both turn on while on low beams would it be like I had the high beams on or would it be dim like the other one and would I be able to still use the high beams?
Just leave it. That's how they wanted it from factory then I wouldn't touch it.
They also wanted it stock or they would ave put power commanders and stuff on em :P but ya I prob will leave them that way and anyways are power commander 3s are to install do u have to do anything like programming it in?
hahaha. Newb :P Yeah that's normal all hondas with duel headlights are like that. As for the PCIII's you have to download a map (program) to the unit then I'm pretty sure it just piggy backs to the ECU. Not positive on that though. I did see one on ebay the other day for fifty bucks buyitnow if you're looking....
power commanders really dont make the f4i faster........... they make it run better after u mess up its stock map with a new slip on or filter
and the high beam can NEVER be a low beam, its angled different, youll have to angle it down, u might as well just leave it on all the time if u want both lights. |
Originally Posted by vangill
(Post 996416)
and the high beam can NEVER be a low beam, its angled different, youll have to angle it down, u might as well just leave it on all the time if u want both lights. Anyway, regarding the headlights...the actual reflective housings in the low and high beam lens are different. The bulbs are the same. So to run that "mod" someone stated earlier would merely have you running your low and high beam together as default settings which makes no sense to me...to actually have both bulbs at "low beam" you would have to tear out the housing and reinstall another low beam housing in the high beam lens and then angle it appropriately (which I dont know why anyone would ever go through that much labor to do this?) They make some new "ultra bright" H7 bulbs that you could stick in there or do what most do..get a DDM HID kit:icon_bike: |
^Good stuff.
