Grinding brakes
Old 05-18-2010 | 10:02 PM
RekTek's Avatar
Default Grinding brakes
My front brakes seem to sort of grind when coming to a stop. I only notice it at lights/slow speed stuff. It's still smooth feeling, I have a good amount of pad left but it sounds like a car when pads are worn.
Normal?
Thanks for any help
Old 05-18-2010 | 10:08 PM
Kuroshio's Avatar
My rear brake squealed a bit. Usually at slow speeds coming to a stop. Sunday I flushed the brake fluid, took 80 grit sand paper to the pads, cleaned the rotors with brakleen and bled the brakes. No more squeal. Rear brake can now lock the rear wheel.
So when was the last time you flushed the fluid, cleaned the rotors and deglazed the pads?
Old 05-18-2010 | 10:35 PM
vangill's Avatar
July 2010 ROTM
yeah they r prolly just really dirty, clean them up and see if that helps, if not at least it didnt really cost any more than your time
Old 05-19-2010 | 10:15 AM
boredandstroked's Avatar
You have metallic brake pads and multible holes in the rotor cutting into said metal pads. Your going to get noise.
Old 05-19-2010 | 01:06 PM
Jrzy Goat's Avatar
That's the sound of brake pads squeezing rotors. It's normal.
KY_RR_rider
09-04-2013 12:38 PM
cbrspoon
03-23-2011 01:52 AM
lafkosky
05-03-2009 05:40 AM
MrSplean
12-07-2008 12:33 AM
Jaycbrf2
06-19-2006 03:44 PM
Quick Reply: Grinding brakes
