Grinding noise
Old Dec 4, 2008 | 03:45 PM
MrSplean's Avatar
Default Grinding noise
While riding my 2000 f4, i came to a stop light and shifted into neutral. As soon as i let off the clutch i heard a faint but distinct grinding noise. Kinda similar to a civic i had where the throw out bearing was worn. Any ideas?
Old Dec 4, 2008 | 10:24 PM
f3BikeR's Avatar
Default RE: Grinding noise
I always hear that grinding noise while in neutral as well and wondered what causes it!
AS you pull in the clutch, while in neutral, it goes away right?
Old Dec 5, 2008 | 09:41 AM
MrSplean's Avatar
That is correct. Perhaps it's simply the noise it's supposed to make. I don't know.
Old Dec 5, 2008 | 11:50 PM
f3BikeR's Avatar
Same here, I'm curious what others say as to if it's normal or how it can be solved/dealt with!
Old Dec 6, 2008 | 11:31 AM
02cbr's Avatar
Mine does it too. i noticed that it always does it more when it gets time for the oil to be changed. I've run all kinds of oil but the Honda brand does actually seem to help.
Old Dec 6, 2008 | 11:39 AM
MotoDan's Avatar
Well its obviously the transmission. All of the gears are meshed together between the main and counter shafts and every gear on the main shaft side is spinning causing all of the free wheelen gears on the counter shaft to spin (When in Neutral). Mine does the same thing and has done it since I first bought the bike. And I have taken it in for valve adjustments a couple times in between then and now. Asked a tech about it and he said it was normal. I've put over ten thousand miles on the bike since I bought it. So there is nothing to worry about. Its just the sound of your gears running together. It goes away when you pull in the clutch because because the hub which is connected to the main shaft is no longer being driven by the drive plates in the clutch. Therefor the main shaft stops spinning causing all the gears to stop spinning making the sound dissipate. Oil as well can affect how loud the sound gets. Since oil is supposed to be a barrier between metal parts. But the sound will always be there. Hope that makes sense.
Old Dec 6, 2008 | 04:14 PM
f3BikeR's Avatar
motoDan-well put, thanks
SoI take it that when the clutch gets changed, this won't disappear?
Old Dec 6, 2008 | 10:16 PM
MrSplean's Avatar
That makes sense. Thanks moto dan.
Old Dec 6, 2008 | 11:00 PM
MotoDan's Avatar
Nope wouldn't change a thing. I'm sure even if you changed out your transmission it wouldn't change. Unless there was some sorta teflon coating on the gears to dampen the sound and some good oil. But that dosen't exist. Just a normal thing like when you hear your valve train. It will always be there and its completely normal.
Old Dec 6, 2008 | 11:33 PM
f3BikeR's Avatar
understood
thanks for such knowledge, it's satisfying!
Macks
Jun 15, 2009 10:25 PM
Macaco
Oct 26, 2008 10:43 PM
RoadRashHurts904
Apr 27, 2008 06:22 PM
Jaycbrf2
Jun 19, 2006 02:44 PM
cbr6
Aug 22, 2005 02:33 PM
